vano423 Опубликовано 17 мая, 2023 Share Опубликовано 17 мая, 2023 (изменено) Поделюсь опытом замены шкуры водительского поджопника. ВЫбор пал на эту обивку (виниловые сразу отмел) https://www.ebay.com/itm/331718995604?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D249332%26meid%3D66cde0f33b194e96bb0e6f7ef7de3701%26pid%3D101195%26rk%3D10%26rkt%3D12%26sd%3D122139977504%26itm%3D331718995604%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V4V6ItemNrtInQueryAndCassiniVisualRankerAndBertRecallWithVMEV3%26brand%3DSeat&_trksid=p2047675.c101195.m1851&amdata=cksum%3A33171899560466cde0f33b194e96bb0e6f7ef7de3701|enc%3AAQAIAAABUPqB0EgCndAssfMWNy0AT0GytGzF9%2By0G%2BlcW69DgBK3Qlz4BjwJQqPkN4K8I7qz9LY8U%2FWG89Cz8kpoCPe2W%2BwV%2FesQn1W1tlV%2F4u9Gi3R%2Fi2p%2B26bXe5wIgvwB9zB4Bm%2BMZT2qzDVEPWyLpo57EchxKYpt4Zf4PmNZu66YA7hTZK0n3fqjyR4VMT0djHkUaKkLQMrmVcHqDoCb7U7bRxjTCQgR4Cmk74Fwl79AzY7XpbKTtZe3YC9C3kliIDpf56R%2FCL3Gul3QzEi0rQyJYYpNOqDCFP9%2BoMXACLTdlyvxS2D4LFXeJhhCzEKp4TDboJ08N2vAT%2Fgp4FCv0Fhg6eAFNlkm9TjmxdCBVHJ3cQYudbYd3fIftZy0nmL42uFTjJHzlS3AqrInNtsBCZHmRm%2FSQiuSu9K4ZH9K%2BlTVjvNNIRIJhrLUVprUMKGpRmLTfQ%3D%3D|ampid%3APL_CLK|clp%3A2047675&epid=881792738 и эту пену https://www.ebay.com/itm/114583245728?_trkparms=amclksrc%3DITM%26aid%3D1110002%26algo%3DSPLICE.SOI%26ao%3D1%26asc%3D20201210111451%26meid%3D52d2d1803c5f4eb9a7c4115e52e409bb%26pid%3D101196%26rk%3D3%26rkt%3D12%26sd%3D113250739617%26itm%3D114583245728%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DPromotedSellersOtherItemsV2WithMLRv3&_trksid=p2047675.c101196.m2219&amdata=cksum%3A11458324572852d2d1803c5f4eb9a7c4115e52e409bb|enc%3AAQAGAAABACtrZQ7uyU6NyRWMuc0OogoSa%2FUIDys%2F02w7jR10vOAtCWiFa%2BRLUAIp3oF9CC8z%2FUlARejRPX%2Bg1nCt32YphbVPSda77glHTMZcTmz4Xs3T770UwEQ0QL2m0JZQ5CwoM%2FX2Uj6n5digG8BRZrH8nj9piFR%2Fvz%2BFPde0WTkJobrMk%2FykuJIMsW4smG87CNkyNepDGQEdoh5xGpGN8eTLd%2B6D6BMVl6ox0UW65WX6ARwBjGa0nyOsvl%2BrHt6PveAEEcUpe4MGKzPjJhl7YpDSS2v82daLphY%2BvTKFv5T0wkUCBxlIWh2yFVtitTjoZRDt7frKYyw1aWywIDG5lnX9MO8%3D|ampid%3APL_CLK|clp%3A2047675 Пена в итоге оказалась никудышного каества. И с кучей подрезок я ее решил не ставить. Да и по жесткости она жесткая и нкомфортная. РОдной поролон оказался вполне себе живым и не продавленным (18 лет машине. во мне 125 кг) и решено было оставить его. Что в итоге: Теперь о установке: Снимать седло не обязательно, достаточно открутить 2 гайки м8 спереди, и тащить сидушку на себе и потом ее приподнять. Потом нащупать рукой зацепки шкуры, откинуть их сзади и снять шкуру, потом вытащить поролон и уже отстегивать проводку от каркаса. при том что мучиться и разьединять разьемы не надо. Я бы вообще разрезал старую сидушку сверху и все. Теперь о самой обивке - все сдално как в оригинале. Центр и боковины кожа. нижняя часть кожзам. По качеству кожа и одновременно толстая и эластичная и гладкая. Внутри подкладка из синтепона. есть зацепки для поролона. Одевать пришлось помучиться минут 20. Изменено 17 мая, 2023 пользователем vano423 (смотреть историю редактирования) Ссылка на комментарий Share on other sites More sharing options...
DRB Опубликовано 17 мая, 2023 Share Опубликовано 17 мая, 2023 С поролоном в итоге так ничего и не сделал что ли? Тогда угол сиденья левый просто в прекрасном состоянии по поролону, несмотря на декларируемую массу)) Ссылка на комментарий Share on other sites More sharing options...
vano423 Опубликовано 18 мая, 2023 Автор Share Опубликовано 18 мая, 2023 14 часов назад, DRB сказал: С поролоном в итоге так ничего и не сделал что ли? Тогда угол сиденья левый просто в прекрасном состоянии по поролону, несмотря на декларируемую массу)) Поролон оставил стоковый. он оказался не продавленный. и воплне симметричный. Новодельная пена гораздо тверже и уже при установке и кучи подрезок начала равться. Дрянь полная. Чтобы седло боковинка не уродовалась просто закидываю задницу на седло. а не ползу на него/с него. мой рост 196 позволяет это сделать Ссылка на комментарий Share on other sites More sharing options...
MAXRED Опубликовано 20 мая, 2023 Share Опубликовано 20 мая, 2023 (изменено) Добавлю магазин. Я заказывал у данного продавца обивку под зад https://www.ebay.com/itm/264057830509 под родной код обивки. Соответствует узор оригиналу. Изменено 23 мая, 2023 пользователем MAXRED (смотреть историю редактирования) Ссылка на комментарий Share on other sites More sharing options...
vano423 Опубликовано 22 мая, 2023 Автор Share Опубликовано 22 мая, 2023 https://www.ebay.com/itm/262337593542?hash=item3d148a00c6:g:wNQAAOSwnbZYEPYf Полчается что и на жм у него есть все. И цена такая же как я брал - 92 бакса. но на фото нет выреза под панельку. В оиригинале и на моем там кроме выреза еще пластинка должна быть пластиковая для жесткости выреза. Ссылка на комментарий Share on other sites More sharing options...
onx Опубликовано 22 мая, 2023 Share Опубликовано 22 мая, 2023 Как теперь с ebay это заказывается? У меня аналогичная проблема, заказал обивку с алика, но она явно хуже качеством Ссылка на комментарий Share on other sites More sharing options...
vano423 Опубликовано 22 мая, 2023 Автор Share Опубликовано 22 мая, 2023 (изменено) через посредников на авито. Они где то 10% берут от заказа. Если у тебя серая - напиши мне, у меня есть, я свою снятую отдал в ателье - по образцу пошили под оригинал полностью кожаная с подкладкой и ершиками снизу и с фурнитурой от оригинала моего. Решил оставить еще одну про запас.Но вроде как и не нужно особо. Изменено 22 мая, 2023 пользователем vano423 (смотреть историю редактирования) Ссылка на комментарий Share on other sites More sharing options...
ammiak Опубликовано 22 мая, 2023 Share Опубликовано 22 мая, 2023 5 часов назад, onx сказал: Как теперь с ebay это заказывается? У меня аналогичная проблема, заказал обивку с алика, но она явно хуже качеством Никаких проблем, хоть ebay хоть не ebay - пишите на почту в подписи. Ссылка на комментарий Share on other sites More sharing options...
MAXRED Опубликовано 23 мая, 2023 Share Опубликовано 23 мая, 2023 21 час назад, vano423 сказал: https://www.ebay.com/itm/262337593542?hash=item3d148a00c6:g:wNQAAOSwnbZYEPYf Полчается что и на жм у него есть все. И цена такая же как я брал - 92 бакса. но на фото нет выреза под панельку. В оиригинале и на моем там кроме выреза еще пластинка должна быть пластиковая для жесткости выреза. По моей расцветке только у него было. А так с оригиналом цвет и узор совпал, выкройка не очень. Ну и винил потоньше. Ссылка на комментарий Share on other sites More sharing options...
