zilgaz Опубликовано 19 января, 2014 Share Опубликовано 19 января, 2014 (изменено) Нашел на просторах инета взаимосвязь карданов и мостов, может кому понадобятся размеры. Переводить не стал, и так все понятно Если повторяюсь просьба админов снести..... Chapter 3: Axles: 7.5 -> 8.5 swapA 8.5" rear axle from a '84 H/O, 442 or GN is a very simple bolt-in replacement for a 7.5" rear axle that offers the benefits of an improved rear axle ratio and increased strength. Верх 8.5 Низ 7.5 At first glance the two axle assemblies above may look identical. In fact the foremost assembly is a 7.5" axle and the assembly in the background is a 8.5" axle. Aside from that, they are identical. The same upper and lower control arms are used, the brake parts are identical. In fact the only change required to swap an 8.5" axle in place of a 7.5" axle is a 0.99" shorter driveshaft ( OK, call it one inch).Courtesy of Steve Ochs:For all applications EXCEPT as listed below:2.50" O.D. x 0.065" Wall Thickness x 52.42" longPink-PinkFor Monte Carlo SS ONLY (H.O. V-8):2.75" O.D. x 0.065" Wall Thickness x 52.42" longBrown-GreenFor Hurst Olds/442 and Turbo Regal/Grand National (8.5" Ring Gear):2.75" O.D. x 0.065" Wall Thickness x 51.43" longPurple-GreenAll lengths are from center to center of u-joints.Colors are the color of the crayon stripes on O.D. of tube near middle of shaftOf note is the shorter driveshaft used for the 8.5", 0.99" to be exact, also note that there is no mention of transmissions. All factory installed transmissions, THM200C, THM250©, THM350C and the THM200-4r all used the same length driveshaft. Длинна верхнего кардана 59 дюймов - 150 см нижнего кардана 63 дюйма - 160 см. Взято здесь http://tech.oldsgmail.com/axle_75to85.php Изменено 20 января, 2014 пользователем zilgaz (смотреть историю редактирования) Цитата Ссылка на комментарий Share on other sites More sharing options...
ЛюбительФордов Опубликовано 19 января, 2014 Share Опубликовано 19 января, 2014 Длинна верхнего кардана 60 дюймов - 150 см нижнего кардана 63 дюйма - 160 см. 3 дюйма это не 10см. Цитата Ссылка на комментарий Share on other sites More sharing options...
zilgaz Опубликовано 19 января, 2014 Автор Share Опубликовано 19 января, 2014 (изменено) 3 дюйма это не 10см. 150 см = 59.0551181 дюйма 160 см = 62.992126 дюйма гоголь рулит Изменено 20 января, 2014 пользователем zilgaz (смотреть историю редактирования) Цитата Ссылка на комментарий Share on other sites More sharing options...
CAUTION FAN Опубликовано 19 января, 2014 Share Опубликовано 19 января, 2014 Если повторяюсь просьба админов снести..... Долго не мог осилить... Цитата Ссылка на комментарий Share on other sites More sharing options...
