GOA Опубликовано 8 ноября, 2008 Share Опубликовано 8 ноября, 2008 подскажите как снять бак на Chevy Tahoe 96 года... может у кого есть мануал? буду благодарен! Цитата Ссылка на комментарий Share on other sites More sharing options...
root Опубликовано 8 ноября, 2008 Share Опубликовано 8 ноября, 2008 Бензиновый 5.7 Fuel TankRemoval & Installation Side Tank To Remove: Drain fuel tank. Raise and safely support vehicle. Loosen fuel neck hose clamp at fuel tank and disconnect filler neck from tank. Support tank and remove tank support straps and insulator strips. Remove frame mounted bracket (except extended cab). Lower fuel tank shield. Lower fuel tank enough to gain access to fuel and electrical connections. Disconnect fuel feed and vapor hoses. Disconnect electrical connectors. Remove fuel sender assembly and seal ring. To Install: Install NEW seal ring and install sender. Raise tank enough to connect fuel feed/vapor hoses and electrical connector. Raise tank fully. Install fuel tank shield. Connect fuel tank filler neck to tank and tighten clamp. CAUTION Tighten strap fasteners in steps, alternating between the fasteners, until proper torque is reached. Failure to tighten the strap fasteners as directed will cause bottom of tank to deform. Fuel gauge may read improper fuel level if this occurs. Install fuel tank brackets and insulator strips. Torque nuts to: 115 in lbs. (13 Nm). Install fuel tank filler cap. Connect battery negative cable. Turn ignition switch OFF and ON and check for fuel leaks. Rear Tank To Remove: Drain fuel tank. Raise and safely support vehicle. Remove fuel tank off-road shield (if equipped). Loosen fuel neck hose clamp at fuel tank and disconnect filler neck from tank. Support tank and remove tank support straps and insulator strips. Lower fuel tank enough to gain access to fuel and electrical connections. Disconnect fuel feed and vapor hoses. Disconnect electrical connectors. Remove fuel sender assembly and seal ring. To Install: Install NEW seal ring and install sender. Raise tank enough to connect fuel feed/vapor hoses and electrical connector. Raise tank fully. Install fuel tank shield. Connect fuel tank filler neck to tank and tighten clamp. CAUTION Tighten strap fasteners in steps, alternating between the fasteners, until proper torque is reached. Failure to tighten the strap fasteners as directed will cause bottom of tank to deform. Fuel gauge may read improper fuel level if this occurs. Install fuel tank brackets and insulator strips. Torque nuts to: 47 ft lbs. (35 Nm). Install fuel tank off-road shield (if equipped). Install fuel tank filler cap. Connect battery negative cable. Turn ignition switch OFF and ON and check for fuel leaks. GM_05_00_998L.gif GM_05_00_999L.gif Цитата Ссылка на комментарий Share on other sites More sharing options...
GOA Опубликовано 9 ноября, 2008 Автор Share Опубликовано 9 ноября, 2008 спасибо Цитата Ссылка на комментарий Share on other sites More sharing options...
root Опубликовано 9 ноября, 2008 Share Опубликовано 9 ноября, 2008 спасибо Бензин? Еще по дизельному Тахо есть. Цитата Ссылка на комментарий Share on other sites More sharing options...
GOA Опубликовано 9 ноября, 2008 Автор Share Опубликовано 9 ноября, 2008 5.7 бензин. Обязательно бак снимать или есть тех отверстие в кузове? Цитата Ссылка на комментарий Share on other sites More sharing options...
rewers22 Опубликовано 9 ноября, 2008 Share Опубликовано 9 ноября, 2008 5.7 бензин. Обязательно бак снимать или есть тех отверстие в кузове? Если никто особо хитрый не сделал-то в оригинале нет отверстий. Бак снимать -час -ставить еще быстрее То ли дело на камаре-чтоб поменять насос -надо снять бак,чтоб ы снять бак надо снять мост задний,ну и глушитель до кучи.. Цитата Ссылка на комментарий Share on other sites More sharing options...
GOA Опубликовано 9 ноября, 2008 Автор Share Опубликовано 9 ноября, 2008 дааа....на больное место надовил...очень жалею что продал КАМАРа Цитата Ссылка на комментарий Share on other sites More sharing options...
STiNGER Опубликовано 10 ноября, 2008 Share Опубликовано 10 ноября, 2008 То ли дело на камаре-чтоб поменять насос -надо снять бак,чтоб ы снять бак надо снять мост задний,ну и глушитель до кучи.. Да уж, последовательность такая: Цитата Ссылка на комментарий Share on other sites More sharing options...
Teddi Опубликовано 10 ноября, 2008 Share Опубликовано 10 ноября, 2008 То ли дело на камаре-чтоб поменять насос -надо снять бак' date='чтоб ы снять бак надо снять мост задний' date='ну и глушитель до кучи..[/quote''] Да уж, последовательность такая: Болгарка рулит Цитата Ссылка на комментарий Share on other sites More sharing options...
ANG Опубликовано 10 ноября, 2008 Share Опубликовано 10 ноября, 2008 То ли дело на камаре-чтоб поменять насос -надо снять бак,чтоб ы снять бак надо снять мост задний,ну и глушитель до кучи.. Да уж, последовательность такая: Болгарка рулит +1. это первое, что сделал полезного в камаре. Цитата Ссылка на комментарий Share on other sites More sharing options...
rewers22 Опубликовано 10 ноября, 2008 Share Опубликовано 10 ноября, 2008 Господа трех геншики! это на тригене все просто-дырко порезал и выдрал... Я на кабрике чтоб насос вынуть дыру 30 на 50 см вырезал- и то бак пришлось отвинтить..ГМнегры рулят-они к сендеру насоса еще полуметровые хитровыебанные трубки намертво приделали Пля ..а еще у меня ж кабрик-крышку то не откинешь-дырко четко под стеклом-утрахалсо пилить. Цитата Ссылка на комментарий Share on other sites More sharing options...
Teddi Опубликовано 10 ноября, 2008 Share Опубликовано 10 ноября, 2008 Во во Серега-4ген очень сильно заколдован Цитата Ссылка на комментарий Share on other sites More sharing options...
winsvega Опубликовано 11 ноября, 2008 Share Опубликовано 11 ноября, 2008 То ли дело на камаре-чтоб поменять насос -надо снять бак,чтоб ы снять бак надо снять мост задний,ну и глушитель до кучи.. Да уж, последовательность такая: :1: :( вопрос ! 1. снял глушак 2. насколько нужно снимать мост ??? вабще выкатывать ??? ... или хватит как нить вывесить .. ?? и судя по одной из тем .. его еще надо настраивать ((( Цитата Ссылка на комментарий Share on other sites More sharing options...
rewers22 Опубликовано 11 ноября, 2008 Share Опубликовано 11 ноября, 2008 то winsvega-у тебя триген-просто вырежи окно и не мучайся. Мост савсем снимать.Иначе натрахаисся.Ставить обратно -ничего настраивать не надо. Цитата Ссылка на комментарий Share on other sites More sharing options...
winsvega Опубликовано 11 ноября, 2008 Share Опубликовано 11 ноября, 2008 то winsvega-у тебя триген-просто вырежи окно и не мучайся. Мост савсем снимать.Иначе натрахаисся.Ставить обратно -ничего настраивать не надо. спасиб! там все равно все перетряхивать, пружины, аморты, сайленты .. и т.п т.д Цитата Ссылка на комментарий Share on other sites More sharing options...
