legaleks Опубликовано 30 июля, 2014 Share Опубликовано 30 июля, 2014 Народ требуется ваша помощь. Какой стандартный размер шеек коленвала корень/шатун на 305 смал блоке v8 5L 88 года? Цитата Ссылка на комментарий Share on other sites More sharing options...
motovoz Опубликовано 30 июля, 2014 Share Опубликовано 30 июля, 2014 http://www.gearheadgeek.com/ghgj/index.php/49-54-data/general-chevy-data/crankshaft-journal-sizes CrankshaftThe 305 engine used a cast iron crankshaft that was secured in the block with two bolt main caps. The rear oil seal used from 1976 until 1986 is a two piece design. After 1986 Chevrolet switched to a one piece rear main seal design and as a result, 305 crankshafts produced before 1986 will not interchange with those manufactured after without fitting special adapters to the engine block. The crankshaft's main journals were 2.450 inches in diameter and the rod journals 2.100 inches. Цитата Ссылка на комментарий Share on other sites More sharing options...
