highwaychile Опубликовано 21 января, 2009 Share Опубликовано 21 января, 2009 1G1BN53E6NW159844 Цитата Ссылка на комментарий Share on other sites More sharing options...
VK Опубликовано 21 января, 2009 Share Опубликовано 21 января, 2009 1:U.S. BUILT G:GENERAL MOTORS G:SUZUKI 1:CHEVROLET BN:CAPRICE 5:FOUR-DOOR SEDAN (19,69) 3:ACTIVE (MANUAL) BELTS W/DRIVER INFLATABLE RESTRAINT SYSTEM E:ENG OPT - L03 DISP - 5.0L CYL - V8 FUEL SYS - TBI DIV - 1,2,3,4,6 PROD IN - U.S. CANADA 6:CHECK DIGIT N:1992 MODEL YEAR W:IWATA JAPAN W:WILLOW RUN MI 159844: PRODUCTION SEQUENCE 12A = STRIPE - ACCENT, TWO TONE, LIGHT GRAY/RED (12A) 149 = SEAT BELT COLOR LT GRAY (149) 14C = TRIM COMBINATION CLOTH, GRAY (14C) 14I = INTERIOR TRIM LT GRAY (14I) 1SB = PACKAGE-OPTION 02 (1SB) 28Q = MOLDING COLOR,BLACK SAPPHIRE METALLIC (28Q) 28U = EXTERIOR COLOR,PRIMARY (28U) 5AN = TIRE ALL-P225/70HR TIRE OPT(5AN) 6TS = COMPONENT-COMPUTER SELECTED SUSPENSION SUSP(6TS) 7TS = COMPONET-COMPUTER SELECTED SUSPENSION SUSP(7TS) 8RJ = COMPONENT RR LH - COMPUTER SEL SUSP (8RJ) SUSP(8RJ) 9RJ = COMPONENT RR RH - COMPUTER SEL SUSP (9RJ) SUSP(9RJ) A90 = LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) AA7 = WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7) AG1 = ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1) AJ3 = RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) AM6 = SEAT,FRONT SPLIT,3 PASSENGER WITH CENTER ARMREST FRT SPLIT ST(AM6) AU3 = LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) B18 = ORNAMENTATION,INTERIOR(DELUXE) DELUXE INTR(B18) B34 = COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34) B37 = COVERING,FLOOR MATS,FRONT AND REAR AUXILIARY FRT/RR AUX FLR MATS(B37) BY1 = ORNAMENTATION,EXTERIOR,BODY EMBLEM BODY EMB(BY1) C49 = DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) C60 = AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) C71 = LAMP,INTERIOR,FRONT DOOR COURTESY FRT DR CTSY LP(C71) CD2 = INDICATOR,WINDSHIELD WASHER FLUID LOW FLUID IND(CD2) D64 = MIRROR,INSIDE,RH VISOR VANITY,ILLUMINATED ILLUM S/S MIR(D64) D7A = GEAR-SPEEDOMETER DRIVEN (25513042) (D7A) D85 = STRIPE,BODY SIDE LOWER ACCENT(CAN BE PAINTED OR MATERIAL) LWR BODY SI ACNT STRPE(D85) D8N = SENSOR VEH SPD (10456088) (D8N) DC4 = MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) DL8 = MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG ELEC R/CON HTD O/S MIR(DL8) E5Z E9Z EXP = EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP) F41 = SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR FIRM RIDE & HANDLING SUSP(F41) GM8 = AXLE REAR 3.45 RATIO 3.45R(GM8) IQC JA1 = BRAKE SYSTEM,LIGHT WEIGHT,DISC,DRUM LGT WT BRK SYS(JA1) JM4 = BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4) K34 = CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) K60 = GENERATOR,100 AMPERE 100 AMP(K60) KC4 = COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) L03 = ENGINE,5.0L(5.0E),V8(T.B.I) 5.0E(L03) MAG = MARKETING AREA GULF STATES ORGANIZATION(EXPORT) GULF STATES(MAG)(EXPORT) MD8 = TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) MX0 = TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0) N30 = STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30) N40 = STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40) N81 = TIRE,SPARE(FULL SIZE RADIAL) FULL SIZE RADIAL SPA(N81) NA5 = EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) NM8 = EMISSION SYSTEM,LEADED FUEL EXPORT LEADED FUEL EMIS EXPORT (NM8) P17 = COVER,SPARE WHEEL AND TIRE(FULL SIZE SPARE) SPA TIRE CVR(P17) PA5 = CAP,HUB(SPORT) SPORT WHL HUBCAP(PA5) PB4 = LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4) PD4 = WHEEL-15 X 7 LIGHT METAL ALLOY, 5 SPOKE 5 SPOKE AL WHL(PD4) T87 = LAMP,CORNERING COR LP(T87) U18 = SPEEDOMETER,INSTRUMENT,KILOMETER(EXPORT) KILOMETER SPEEDO(U18) U38 = WARNING,LOW COOLANT CLNT WRNG(U38) U39 = CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TRIP ODOMETER) GA CSTR(U39) U41 = INDICATOR,LOW FUEL LOW FUEL IND(U41) U73 = ANTENNA,FIXED FIXED ANT(U73) UD4 = ALARM,VEHICLE SPEED(120 KPH) 120 KPH ALARM(UD4) UM6 = RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) UQ1 = RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) UQ5 = SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED 4 SPKR SYS(UQ5) UW1 = DIAGNOSTIC SYSTEM DIAGN SYS(UW1) V08 = COOLING SYSTEM,HEAVY DUTY HVY DUTY CLG(V08) V87 VC5 = LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL USED OUTSIDE U.S. AND JAPAN(VC5) VG9 = PROTECTOR WAX,EXT BODY(EXPORT) PROTECTIVE BODY WAX(VG9) VK3 = LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) WRN Z09 = CAPRICE CLASSIC(MERCHANDISING OPTION)(1BL19 & Z09 = 1BN19) CAPRICE CLASSIC(Z09) Цитата Ссылка на комментарий Share on other sites More sharing options...
ammiak Опубликовано 21 января, 2009 Share Опубликовано 21 января, 2009 92 Suzuki Caprice from Iwata Japan ну вот шевиводам бальзам на душу, иппонцы=неломучее говно Цитата Ссылка на комментарий Share on other sites More sharing options...
VK Опубликовано 21 января, 2009 Share Опубликовано 21 января, 2009 92 Suzuki Caprice from Iwata Japan ну вот шевиводам бальзам на душу, иппонцы=неломучее говно EPC такой :-P Он варианты выводит. Тем не менее партнамберы и кОртинге выводит правильные - ибо знает что это каприс :-P Вот. Цитата Ссылка на комментарий Share on other sites More sharing options...
ammiak Опубликовано 21 января, 2009 Share Опубликовано 21 января, 2009 EPC такой :-PОн варианты выводит. Тем не менее партнамберы и кОртинге выводит правильные - ибо знает что это каприс :-P Вот. ЕИРЦ знаю, ЕРС низнаю чоза шняга... каприсоводческая? Цитата Ссылка на комментарий Share on other sites More sharing options...
VK Опубликовано 21 января, 2009 Share Опубликовано 21 января, 2009 EPC такой :-P Он варианты выводит. Тем не менее партнамберы и кОртинге выводит правильные - ибо знает что это каприс :-P Вот. ЕИРЦ знаю, ЕРС низнаю чоза шняга... каприсоводческая? Бери выше - GMоводческая... Нитошта у форта, ога... Extraordinary Perfomance for Chevy/Caddy Както так вроде Цитата Ссылка на комментарий Share on other sites More sharing options...
Eaton Опубликовано 21 января, 2009 Share Опубликовано 21 января, 2009 Extraordinary Perfomance for Chevy/Caddy Както так вроде интересная этимология названия... чо-то вы фантазируете, любезный у меня вот на компе Chrysler EPC обитает. и какая связь между твоей расшифровкой и тем, что это каталог запчастей, грубо говоря?? а не кажеца ли что Electronic Parts Catalog? Цитата Ссылка на комментарий Share on other sites More sharing options...
VK Опубликовано 22 января, 2009 Share Опубликовано 22 января, 2009 Extraordinary Perfomance for Chevy/Caddy Както так вроде интересная этимология названия... чо-то вы фантазируете, любезный у меня вот на компе Chrysler EPC обитает. и какая связь между твоей расшифровкой и тем, что это каталог запчастей, грубо говоря?? а не кажеца ли что Electronic Parts Catalog? Keep a good sense of humor 'bout it Цитата Ссылка на комментарий Share on other sites More sharing options...
Eaton Опубликовано 22 января, 2009 Share Опубликовано 22 января, 2009 Keep a good sense of humor 'bout it hell yeah, man Цитата Ссылка на комментарий Share on other sites More sharing options...
highwaychile Опубликовано 27 января, 2009 Автор Share Опубликовано 27 января, 2009 ээээ...пасиб...ну я вообще хотел...и сторию авто своего узнать...на CARFAXe вроде это пробивается.. Цитата Ссылка на комментарий Share on other sites More sharing options...
escapeman Опубликовано 27 января, 2009 Share Опубликовано 27 января, 2009 А это за 300 р на нескольких сайтах наших, оплата смс-ской. Что-то типа carfax.ru Цитата Ссылка на комментарий Share on other sites More sharing options...
Eaton Опубликовано 27 января, 2009 Share Опубликовано 27 января, 2009 А это за 300 р на нескольких сайтах наших, оплата смс-ской.Что-то типа carfax.ru www.vinfax.ru не рекламирую но: 1. Честно, без кидалова 2. 150 рублей карфакс и 150 авточек vinbox.ru меня нагрели, %№*ди! Цитата Ссылка на комментарий Share on other sites More sharing options...
Гена_Букин Опубликовано 27 января, 2009 Share Опубликовано 27 января, 2009 Ребята, а вин мопаровский, который табличкой, с большим кол-воб букав можите расшифровать я завтра, наверна его напишу..щас лень уже Цитата Ссылка на комментарий Share on other sites More sharing options...
Eaton Опубликовано 27 января, 2009 Share Опубликовано 27 января, 2009 Ребята, а вин мопаровский, который табличкой, с большим кол-воб букав можите расшифровать я завтра, наверна его напишу..щас лень уже карфакс тама с 81 года штоль инфу держит... По-моему твой не попадает в область его ведения. Или тебе просто параметры нужны, а не история?? Цитата Ссылка на комментарий Share on other sites More sharing options...
6061966 Опубликовано 31 января, 2009 Share Опубликовано 31 января, 2009 Друзья, а подскажите по комплектухе: 1G6KF52Y1SU276483. А то интерестно, что с завода внутрь напихали, а глянуть негде. Заранее благодарю!!!. Цитата Ссылка на комментарий Share on other sites More sharing options...
3XL Опубликовано 31 января, 2009 Share Опубликовано 31 января, 2009 Друзья, а подскажите по комплектухе: 1G6KF52Y1SU276483. А то интерестно, что с завода внутрь напихали, а глянуть негде. Заранее благодарю!!!. . Цитата Ссылка на комментарий Share on other sites More sharing options...
6061966 Опубликовано 2 февраля, 2009 Share Опубликовано 2 февраля, 2009 3XL, благодарю!!! А расшифровку опций где можно взять? :( Цитата Ссылка на комментарий Share on other sites More sharing options...
zer Опубликовано 20 марта, 2009 Share Опубликовано 20 марта, 2009 http://www.c2e.info/rpocodes/ Цитата Ссылка на комментарий Share on other sites More sharing options...
6061966 Опубликовано 31 марта, 2009 Share Опубликовано 31 марта, 2009 Благодарю !!! ЗЫ. Вот еще один адрес : http://www.cadillacfaq.com/rpo/index.php В вышеупомянутом не все кода есть, например 6LR,7LR не расшифрованы, а этот показывает. :1: Цитата Ссылка на комментарий Share on other sites More sharing options...
deeniss Опубликовано 5 апреля, 2009 Share Опубликовано 5 апреля, 2009 1G1BN53E6NW159844 Year/Make/Model: 1992 CHEVROLET CAPRICE CLASSIC/LTZ Body Style: SEDAN 4 DR Engine Type: 5.0L V8 TBI OHV 16V Manufactured In: UNITED STATES Цитата Ссылка на комментарий Share on other sites More sharing options...
OldPapa Опубликовано 6 апреля, 2009 Share Опубликовано 6 апреля, 2009 Удобно пробивать тут: www.freevin.ru, не подумайте что реклама, бесплатно, сам проверял.... Цитата Ссылка на комментарий Share on other sites More sharing options...
