Mastermind Posted November 29, 2022 Share Posted November 29, 2022 (edited) Новый распредвал Basic Operating RPM Range: 1,600-5,400 Intake Duration at 050 inch Lift: 218 Exhaust Duration at 050 inch Lift: 224 Duration at 050 inch Lift: 218 int./224 exh. Advertised Intake Duration: 270 Advertised Exhaust Duration: 276 Advertised Duration: 270 int./276 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.495 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.502 in. Valve Lift with Factory Rocker Arm Ratio: 0.495 int./0.502 exh. Lobe Separation (degrees): 110 15000 р. 8 965 73l 86 15 Егор whats app Edited January 22 by Mastermind (see edit history) Quote Link to comment Share on other sites More sharing options...
zer Posted November 29, 2022 Share Posted November 29, 2022 Добавлю. Notes: Designed for early non-roller blocks. Requires thrust button and wear plate. Quote Link to comment Share on other sites More sharing options...
Mastermind Posted December 14, 2022 Author Share Posted December 14, 2022 Ап Quote Link to comment Share on other sites More sharing options...
Mastermind Posted January 14 Author Share Posted January 14 Ап Quote Link to comment Share on other sites More sharing options...
Join the conversation
