Продаю моста дана 60 комплект передний и задний ( дисковые тормоза)
HERE I HAVE A SET OF CHEVY 1 1/2 TON FRONT IS A DANA 60 OPEN 456 GEARS, WARN LOCK OUTS, AND THE REAR IS 14 BOLT WITH 456 GEARS, DETROIT LOCKER. THE FRONT HAS BEEN SODA BLASTED, PAINTED, GEARS AND BEARING INSPECTED AND REPACKED, SEALS BEEN REPLACED, ALSO HAS NEW FRONT CALIPERS, AND PADS. THE REAR 14 BOLT BEEN SODA BLASTED, PAINTED, GEARS INSPECTED WITH A GOOD WORKING DETROIT, NEW SEALS, AND CONVERTED TO DISC BRAKES (NEW CALIPERS, NEW PADS, BOLT ON BRAKES, OUTER RUBBER BRAKE LINE THAT ALLOW YOU TO USE YOUR ORGINALLY HARD LINES). THESE AXLES ARE READY TO BE BOLTED IN, ALL THEY NEED IS GEAR DOPE, THE GEARS IN AXLES BEEN SPRAYED DOWN WTH LITHUIM GREASE, AND SEALED. GREAT FOR A ROCK CRAWLER, OR UPGRADE YOUR FACTORY AXLES TO 1 TON. FOR ADDITIONAL COST I ALSO HAVE OTHER SETS IN STOCK DANA 60 WITH TRAC LOCKS, ALSO CARRY HIGH STEER ARMS IN STOCK, CUSTOM HEAVY DUTY TIE ROD END WITH 3/4 HEIMS, HYDRALIC CYLINDERS IN STOCK, WE CAN BUILD TO YOUR SPECIFICATION. ALSO CAN ADD EMERGENCY BRAKE TO 14 BOLT FOR ADDITIONAL COST.
Price 8500$
Мосты в Москве
